Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The shutter button is one of the most commonly used buttons on a camera. Therefore, it is also the most likely to break.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Slide open the battery cover.
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Slide the battery out of the battery compartment. Slide the battery out of the battery compartment.
    • Slide the battery out of the battery compartment.
  3. Two Phillips screws need to be removed  using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing.  the lower screw is visible on the panel. The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Remove the right side cover from the camera casing.
    • Remove the right side cover from the camera casing.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  7. Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  8. Remove the left side cover from the camera.
    • Remove the left side cover from the camera.
  9. Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  10. Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it. Remove the internal camera components and layout out all pieces on a clean surface.
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  11. Unscrew one .235 inch long Phillips screw using a #00 Phillips screwdriver from the top of the camera.
    • Unscrew one .235 inch long Phillips screw using a #00 Phillips screwdriver from the top of the camera.
  12. Gently remove the shutter button unit from the rest of the camera.
    • Gently remove the shutter button unit from the rest of the camera.
Abschluss
Taylor Shields
831 Reputation
8 Anleitungen geschrieben
Clemson, Team 2-1, Benson Fall 2014 Mitglied von Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 77
