Zum Hauptinhalt wechseln
Canon PowerShot SD700 E18 Error Replacement
Was du brauchst
  1. Canon PowerShot SD700 E18 Error Replacement, Outside Case: Schritt 1, Bild 1 von 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 E18 Error Replacement: Schritt 2, Bild 1 von 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 E18 Error Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 E18 Error Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 E18 Error Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 E18 Error Replacement: Schritt 6, Bild 1 von 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. In diesem Schritt verwendetes Werkzeug:
    Dust Blower
    Kaufen
    • Clean the lens and the area surrounding the lens with a soft brush and dust blower.
    • Tweezers can be helpful when removing sand.
    • Reassemble the camera and if the E18 error persists, further disassembly of the camera may be required.
Abschluss
To reassemble your device, follow steps 1-6 instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Aaron Lee
212 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 9-71, Walters Spring 2011 Mitglied von Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 2,912
