Einleitung
If you experience the E18 error, go to this site and try their solutions.
If you still experience the error, you can follow this guide to disassemble the camera and manually clean the inside of the camera and the lens.
Was du brauchst
Turn off the camera by pressing the power button above the LCD screen.
Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
In diesem Schritt verwendetes Werkzeug:Dust Blower$4.99
Clean the lens and the area surrounding the lens with a soft brush and dust blower.
To reassemble your device, follow steps 1-6 instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
