Einleitung
Follow these steps to remove and install a new LCD screen.
Was du brauchst
Turn off the camera by pressing the power button above the LCD screen.
Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
Remove the two screws that connect the LCD and backlight to the main body of the camera.
Gently pry the LCD and the backlight from the main body of the camera.
Gently pry the LCD from the backlight.
The thin ribbon cable is for the backlight.
The thick ribbon cable is for the LCD screen.
Carefully lift the ZIF connector that covers the thick ribbon cable.
This ZIF connector is fragile. Use caution when lifting it from its down position.
Insert the new LCD and reassemble the camera.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
