Zum Hauptinhalt wechseln
Canon PowerShot SD700 LCD screen Replacement
Was du brauchst
  1. Canon PowerShot SD700 LCD screen Replacement, Outside Case: Schritt 1, Bild 1 von 1
    • Turn off the camera by pressing the power button above the LCD screen.
  2. Canon PowerShot SD700 LCD screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
  3. Canon PowerShot SD700 LCD screen Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
  4. Canon PowerShot SD700 LCD screen Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
  5. Canon PowerShot SD700 LCD screen Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
    • This screw will be longer than the rest of the screws.
  6. Canon PowerShot SD700 LCD screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the front, back, and side casings from the camera and set to the side.
  7. Canon PowerShot SD700 LCD screen Replacement, LCD screen: Schritt 7, Bild 1 von 1
    • Remove the two screws that connect the LCD and backlight to the main body of the camera.
  8. Canon PowerShot SD700 LCD screen Replacement: Schritt 8, Bild 1 von 3 Canon PowerShot SD700 LCD screen Replacement: Schritt 8, Bild 2 von 3 Canon PowerShot SD700 LCD screen Replacement: Schritt 8, Bild 3 von 3
    • Gently pry the LCD and the backlight from the main body of the camera.
    • Gently pry the LCD from the backlight.
    • The thin ribbon cable is for the backlight.
    • The thick ribbon cable is for the LCD screen.
  9. Canon PowerShot SD700 LCD screen Replacement: Schritt 9, Bild 1 von 1
    • Carefully lift the ZIF connector that covers the thick ribbon cable.
    • This ZIF connector is fragile. Use caution when lifting it from its down position.
    • Insert the new LCD and reassemble the camera.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Emilio Rossi
113 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 9-71, Walters Spring 2011 Mitglied von Cal Poly, Team 9-71, Walters Spring 2011
CPSU-WALTERS-S11S9G71
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 2,592
