Einleitung
This guide will help you remove and replace the outside case of the Canon PowerShot SD700. Follow the step-by-step instructions to remove the outside case of your Canon PowerShot SD700. You will need Phillips #00 screwdriver to complete the steps throughout the guide.
Was du brauchst
Turn off the camera by pressing the power button above the LCD screen.
Remove the two, small screws on the bottom of the camera using a Phillip's #00 screwdriver.
Use a Phillips #00 screwdriver to remove the two, small screws on the right side of the camera.
Use a Phillips #00 screwdriver to remove the screw on the left of the camera under the A/V out Digital label.
Use a Phillips #00 screwdriver, remove the screw on the bottom of the camera near the battery and memory card slots.
To reassemble your device, follow steps 1-6 instructions in reverse order.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
