Einleitung
This manual is for replacing the function/set button located on the back of the camera.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using your fingernail, slide the light gray tab towards edge of camera.
Slide the light gray door and pull up to open the door.
Both Battery and Memory Card slots should be visible.
Use your fingernail and slide the small brown tab towards the edge of the camera.
The battery will pop up.
Pull battery straight out of battery holder.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Open the A/V OUT DIGITAL flap on the side of the wrist strap.
Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
Slide light gray door and pull up to open the door.
Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
