Einleitung
This guide is for accessing the cameras internal components for repairs and troubleshooting.
Was du brauchst
Remove the two side screws, indicated by the red circles, using a Phillips #00 screwdriver.
Remove the screw in the battery port, indicated by the blue circle, again using a Phillips #00 screwdriver.
Remove the front face by gently peeling the housing away from the camera.
Remove the back face by using a spudger to lift the tab highlighted in yellow
Pivot the back face clockwise as seen in the second photo.
