Zum Hauptinhalt wechseln
Canon PowerShot SX120 IS Back Cover Replacement
Was du brauchst
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: Schritt 3, Bild 1 von 2 Canon PowerShot SX120 IS Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Back Cover Replacement: Schritt 4, Bild 1 von 2 Canon PowerShot SX120 IS Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: Schritt 6, Bild 1 von 3 Canon PowerShot SX120 IS Back Cover Replacement: Schritt 6, Bild 2 von 3 Canon PowerShot SX120 IS Back Cover Replacement: Schritt 6, Bild 3 von 3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: Schritt 7, Bild 1 von 1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Maria
923 Reputation
1 Anleitung geschrieben
New Mexico State, Team 1-3, Easley Spring 2014 Mitglied von New Mexico State, Team 1-3, Easley Spring 2014
NMSU-EASLEY-S14S1G3
4 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 28
Insgesamt: 1,893
