Zum Hauptinhalt wechseln
Canon PowerShot SX150 IS Buttons Replacement
Was du brauchst
  1. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: Schritt 1, Bild 1 von 3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: Schritt 1, Bild 2 von 3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: Schritt 1, Bild 3 von 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Buttons Replacement, Buttons: Schritt 2, Bild 1 von 3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: Schritt 2, Bild 2 von 3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: Schritt 2, Bild 3 von 3
    • Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
    • Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
  3. Canon PowerShot SX150 IS Buttons Replacement: Schritt 3, Bild 1 von 1
    • Remove the two, 4mm screws from the bottom of the camera. Continue using the same screwdriver from step 1.
  4. Canon PowerShot SX150 IS Buttons Replacement: Schritt 4, Bild 1 von 1
    • Remove back plate from the camera and locate the orange button plate to the right of the screen.
  5. Canon PowerShot SX150 IS Buttons Replacement: Schritt 5, Bild 1 von 3 Canon PowerShot SX150 IS Buttons Replacement: Schritt 5, Bild 2 von 3 Canon PowerShot SX150 IS Buttons Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Once the back plate is removed. Locate the buttons to the right of the screen.
    • Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
    • After lifting the tabs the buttons should come right off, then replace with the new button.
Abschluss
Sam Blanton
461 Reputation
4 Anleitungen geschrieben
Ein Kommentar
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
robert jones - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 539
