Zum Hauptinhalt wechseln
Canon PowerShot SX150 IS Digital Image Sensor Replacement
Was du brauchst
  1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: Schritt 1, Bild 1 von 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: Schritt 1, Bild 2 von 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: Schritt 1, Bild 3 von 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Prerequisite: Schritt 2, Bild 1 von 1
    • Remove the two 2mm screws above the screen using the size J000 screwdriver.
  3. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 3, Bild 1 von 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
    • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
  4. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 4, Bild 1 von 1
    • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
  5. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 5, Bild 1 von 1
    • Remove the plastic panel surrounding the back screen.
  6. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 6, Bild 1 von 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 6, Bild 2 von 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the three 3mm screws using the size J000 screw driver from the button plate.
    • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
    • Move the button plate out of the way.
  7. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 7, Bild 1 von 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 7, Bild 2 von 2
    • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
    • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
  8. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
    • You can then lift the screen out of place and set it aside.
  9. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 9, Bild 1 von 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 9, Bild 2 von 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 9, Bild 3 von 3
    • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
    • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
    • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
  10. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 10, Bild 1 von 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 10, Bild 2 von 2
    • Gently detach the flex ribbon with your tweezers before removing the front plate.
  11. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 11, Bild 1 von 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 11, Bild 2 von 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 11, Bild 3 von 3
    • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
    • Remove the two 5mm screws.
    • Remove the one 3 mm screw.
    • Using the same screwdriver, remove the 3mm screw from the top of the camera.
    • Pull the panel off and set it aside.
  12. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: Schritt 12, Bild 1 von 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: Schritt 12, Bild 2 von 2
    Kaufen
    • Lift the two flex ribbons with your tweezers and remove them.
    • Move the circuit board to the side.
  13. Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 13, Bild 1 von 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: Schritt 13, Bild 2 von 2
    • Remove the three 2 mm screws from around the sensor.
    • Pull the sensor away.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Avery Hyde
146 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 870
