Zum Hauptinhalt wechseln
Canon PowerShot SX160 IS Clock Battery Replacement
Was du brauchst
  1. Canon PowerShot SX160 IS Clock Battery Replacement, Clock Battery: Schritt 1, Bild 1 von 1
    • Locate the internal battery tray on the side of your camera.
  2. Canon PowerShot SX160 IS Clock Battery Replacement: Schritt 2, Bild 1 von 1
    • Use your finger or a spudger to gently pry the battery tray out of the camera.
  3. Canon PowerShot SX160 IS Clock Battery Replacement: Schritt 3, Bild 1 von 1
    • Fully remove the battery tray from the camera.
  4. Canon PowerShot SX160 IS Clock Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove battery from tray and replace.
Abschluss
Congratulations, you have successfully replaced the internal battery. To reassemble your device, follow these instructions in reverse order.
37 weitere Personen haben diese Anleitung absolviert.
Jamie Secretan
1.990 Reputation
6 Anleitungen geschrieben
Colorado Springs, Team 2-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 Mitglieder
17 Kommentare
Clear and simple. Thanks!
Jim - Antwort
I had no idea! Thanks!
natorbett - Antwort
Its not necessary to unscrew the tray.
Afzal Pawaskar - Antwort
Thank you, Jamie!
Casey Cain - Antwort
Gee I thought I am so glad I checked the Internet first...(before I threw it in the trash) that is how frustrating this was. Thank you everyone, I do love this camera
Barbara Rivers - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 58
Letzte 30 Tage: 212
Insgesamt: 50,569
