Zum Hauptinhalt wechseln
Canon PowerShot SX160 IS Function Wheel Replacement
Was du brauchst
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: Schritt 1, Bild 1 von 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: Schritt 1, Bild 2 von 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: Schritt 1, Bild 3 von 3
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot SX160 IS Function Wheel Replacement: Schritt 2, Bild 2 von 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: Schritt 3, Bild 1 von 2 Canon PowerShot SX160 IS Function Wheel Replacement: Schritt 3, Bild 2 von 2
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: Schritt 4, Bild 1 von 1
    • Remove and replace the function wheel.
Abschluss
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
1.990 Reputation
6 Anleitungen geschrieben
Colorado Springs, Team 2-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 Mitglieder
Ein Kommentar
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 620
