Zum Hauptinhalt wechseln
Canon PowerShot SX160 IS Outer Case Replacement
Was du brauchst
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: Schritt 1, Bild 1 von 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: Schritt 1, Bild 2 von 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: Schritt 1, Bild 3 von 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot SX160 IS Outer Case Replacement: Schritt 2, Bild 2 von 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: Schritt 3, Bild 1 von 2 Canon PowerShot SX160 IS Outer Case Replacement: Schritt 3, Bild 2 von 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Jamie Secretan
1.990 Reputation
6 Anleitungen geschrieben
Colorado Springs, Team 2-3, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 Mitglieder
Ein Kommentar
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 23
Insgesamt: 1,966
