Zum Hauptinhalt wechseln
Canon PowerShot SX260 HS Battery Replacement
Was du brauchst
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: Schritt 2, Bild 1 von 2 Canon PowerShot SX260 HS Battery Replacement: Schritt 2, Bild 2 von 2
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
Abschluss
Tyler Kelch
622 Reputation
4 Anleitungen geschrieben
Sam Houston State, Team 11-8, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 11-8, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G8
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 1,080
