Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Refer to this guide if you are having trouble focusing your Canon PowerShot SX280 HS. The AF assist lamp helps to focus the camera when in dimly lit areas, and this guide instructs you on how to replace it. The Essential Electronics Toolkit is required for this replacement.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the outer covering from the camera.
    • Remove the outer covering from the camera.
    • Remove the tabs from the motherboard.
  2. Remove the screws on top of the camera.
    • Remove the screws on top of the camera.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Remove the tabs which will slide out with a chip. The chip is attached to the GPS.
    • Remove the tabs which will slide out with a chip. The chip is attached to the GPS.
  5. Remove the wifi chip.
    • Remove the wifi chip.
    • Remove the screw.
  6. Remove all the screws around the lamp. This releases the lamp.
    • Remove all the screws around the lamp. This releases the lamp.
Abschluss
Osmand A Munoz
228 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-5, Miles Spring 2015 Mitglied von UMass Dartmouth, Team 1-5, Miles Spring 2015
UMASSD-MILES-S15S1G5
3 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 340
