Einleitung
Did you drop your camera and crack the cover? This guide will give you step-by-step instructions on how to remove and replace the back face.
Was du brauchst
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
Pull back the rubber facing to access the A/V and HDMI output compartment.
Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
