Zum Hauptinhalt wechseln
Canon PowerShot SX520 HS Motherboard Replacement
Was du brauchst
  1. Canon PowerShot SX520 HS Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS Motherboard Replacement, Back Face: Schritt 3, Bild 1 von 3 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: Schritt 3, Bild 2 von 3 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: Schritt 3, Bild 3 von 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS Motherboard Replacement: Schritt 5, Bild 1 von 2 Canon PowerShot SX520 HS Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS Motherboard Replacement, LCD Screen: Schritt 7, Bild 1 von 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Carefully pop out the LCD screen with your fingers.
  9. Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: Schritt 9, Bild 1 von 3 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: Schritt 9, Bild 2 von 3 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: Schritt 9, Bild 3 von 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
  10. Canon PowerShot SX520 HS Motherboard Replacement, Lens: Schritt 10, Bild 1 von 1
    • Unlcip the large cable by pulling up on the metal part with your finger.
    • Slide out the 2 smaller cables with your fingers.
  11. Canon PowerShot SX520 HS Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Lift up the lens by grabbing the sides with your fingers.
  12. Canon PowerShot SX520 HS Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Remove 1-2.5 mm screw using a Phillips #000 screwdriver.
  13. Canon PowerShot SX520 HS Motherboard Replacement: Schritt 13, Bild 1 von 2 Canon PowerShot SX520 HS Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Disconnect the two orange serial cables at the top of the motherboard using your fingers.
    • Gently remove the motherboard using your fingers.
    • Too much force will break the motherboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Kyle Crowley
337 Reputation
3 Anleitungen geschrieben
Baylor, Team 4-4, Williams Fall 2015 Mitglied von Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 915
