Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
When your lens isn't working, your camera isn't working. Follow this guide to fix your troubles and get back to taking photographs.
  1. To remove the battery, locate the battery cover on the  bottom of the camera.
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Depress the orange lever holding the battery in place to unlock it.
    • Depress the orange lever holding the battery in place to unlock it.
  3. Use your fingers to remove the battery. Be sure to remember the alignment of the nodes for reassembly.
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver. Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Use an opening tool to gently remove the power and shutter button assembly from the frame.
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
  9. Unscrew the 2mm  screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top) Unscrew the 2mm  screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
  10. Use a Phillips #000 screwdriver to unscrew the 4mm screw.
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
  11. Use a pair of tweezers to remove the no-fuss connector from its holder.
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
  12. Gently lift the protector from the frame.
    • Gently lift the protector from the frame.
  13. Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
  14. Unplug the assembly from the main no-fuss connector.
    • Unplug the assembly from the main no-fuss connector.
  15. Unplug the assembly from its flat-top connection.
    • Unplug the assembly from its flat-top connection.
  16. Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
    • Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
  17. Gently lift the assembly out of its place.
    • Gently lift the assembly out of its place.
  18. Remove the 4 remaining 4mm  screws in the frame with a  Phillips #000 screwdriver.
    • Remove the 4 remaining 4mm screws in the frame with a Phillips #000 screwdriver.
  19. Gently remove the frame. (Make sure to have a firm hold on the rest of the camera at this point) The camera will be loose after this point. Be sure to have a firm hold on it.
    • Gently remove the frame. (Make sure to have a firm hold on the rest of the camera at this point)
    • The camera will be loose after this point. Be sure to have a firm hold on it.
  20. Unplug the ZIF connection between the lens to the main processor.
    • Unplug the ZIF connection between the lens to the main processor.
  21. Detach the flat-top connection.
    • Detach the flat-top connection.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Scott Childress
602 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S6-G4, Lacy Spring 2017 Mitglied von USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 4
Letzten 30 Tage: 15
Insgesamt: 1,230
