Zum Hauptinhalt wechseln
Canon Powershot A70 Front Exterior Panel Replacement
Was du brauchst
  1. Canon Powershot A70 Front Exterior Panel Replacement, Shutter/Speaker Panel: Schritt 1, Bild 1 von 1
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Canon Powershot A70 Front Exterior Panel Replacement: Schritt 2, Bild 1 von 2 Canon Powershot A70 Front Exterior Panel Replacement: Schritt 2, Bild 2 von 2
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Canon Powershot A70 Front Exterior Panel Replacement, Rear Exterior Panel: Schritt 3, Bild 1 von 1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  4. Canon Powershot A70 Front Exterior Panel Replacement: Schritt 4, Bild 1 von 1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  5. Canon Powershot A70 Front Exterior Panel Replacement: Schritt 5, Bild 1 von 3 Canon Powershot A70 Front Exterior Panel Replacement: Schritt 5, Bild 2 von 3 Canon Powershot A70 Front Exterior Panel Replacement: Schritt 5, Bild 3 von 3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  6. Canon Powershot A70 Front Exterior Panel Replacement: Schritt 6, Bild 1 von 2 Canon Powershot A70 Front Exterior Panel Replacement: Schritt 6, Bild 2 von 2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  7. Canon Powershot A70 Front Exterior Panel Replacement: Schritt 7, Bild 1 von 1
    • The interior of the camera should look like this.
  8. Canon Powershot A70 Front Exterior Panel Replacement, Front Exterior Panel: Schritt 8, Bild 1 von 1
    • Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
  9. Canon Powershot A70 Front Exterior Panel Replacement: Schritt 9, Bild 1 von 2 Canon Powershot A70 Front Exterior Panel Replacement: Schritt 9, Bild 2 von 2
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Brian
102 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 14-40, Regan Winter 2010 Mitglied von Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 4,505
