Einleitung
This repair guide will explain, step-by-step the process necessary to replace the LCD Screen.
Ersatzteile
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment.
Open the CF compartment and remove the top screw
The panel, that holds the shutter button and zoom, will come off.
Unscrew the three small screws on the bottom.
remove the wrist strap
Remove the screw in the CF compartment.
Open the rubber Digital AV Out compartment flap.
Pry the battery with the IFIXIT opening tool.
Carefully pull out the battery with two fingers.
Unscrew the two screws that are now visible.
Starting from the bottom, carefully pull the casing off.
The casing will now pivot at the top.
There are three catches that hold the back casing to the body.
The interior of the camera should look like this.
Remove the two screws at the top of the battery compartment.
With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
Three screws hold the viewfinder in place. Two on the top and one on the lens side of the camera.
First, remove the screw in the bent corner of the viewfinder.
Next, remove the 2nd screw directly across from the bent corner. It may be hidden in the space under the orange circuitry.
Lastly, remove the final screw directly under the left side of the viewfinder (on the lens side).
After removing the three screws, the only thing still holding the viewfinder in place is a small plastic peg.
Remove the viewfinder with a firm pull directly upwards.
Remove the two clearly visible screws from the control dial
The dial should come off easily
You should be able to see the two small wires connecting the speaker to a small green plug
With tweezers, carefully unplug the wires from the plug. The wire should slide straight out
Carefully replace the broken speaker/shutter panel with a new one
The removed panel should look like this
Remove the one visible screw that is attaching the flex assembly to the back of the camera.
Starting with the bottom-left corner (below the screen), lift the flex assembly away from the camera chassis.
Locate the small metal tab that attaches the flex assembly to the upper-right corner of the camera, and release it with a fingernail.
Disconnect the black connector by lifting it up, as shown in the picture.
Gently pull the rest of the flex assembly away from the camera body until you reach the last connector.
Hold the flex assembly gently, but firmly, and pull it out of the connection with two fingers.
Remove the two screws from the bottom of the camera.
Remove one screw from the top of the camera.
The screen is no longer screwed to the body.
To pop it off, push down and pull away.
Unplug the thin (towards bottom of camera), orange strip by pulling on it with your thumb and another finger.
It will disconnect from the small white box.
Finally repeat the previous step with the thick, orange strip on the side of the screen.
You have successfully removed the LCD screen and it is ready to be replaced.
