Zum Hauptinhalt wechseln
Canon Powershot A70 Rear Exterior Panel Replacement
Was du brauchst
  1. Canon Powershot A70 Rear Exterior Panel Replacement, Rear Exterior Panel: Schritt 1, Bild 1 von 1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  2. Canon Powershot A70 Rear Exterior Panel Replacement: Schritt 2, Bild 1 von 1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  3. Canon Powershot A70 Rear Exterior Panel Replacement: Schritt 3, Bild 1 von 3 Canon Powershot A70 Rear Exterior Panel Replacement: Schritt 3, Bild 2 von 3 Canon Powershot A70 Rear Exterior Panel Replacement: Schritt 3, Bild 3 von 3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  4. Canon Powershot A70 Rear Exterior Panel Replacement: Schritt 4, Bild 1 von 2 Canon Powershot A70 Rear Exterior Panel Replacement: Schritt 4, Bild 2 von 2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  5. Canon Powershot A70 Rear Exterior Panel Replacement: Schritt 5, Bild 1 von 1
    • The interior of the camera should look like this.
Abschluss
Cal Poly, Team 14-40, Regan Winter 2010 Mitglied von Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 3,277
