Zum Hauptinhalt wechseln
Canon Powershot Pro1 Flash Replacement
Was du brauchst
  1. Canon Powershot Pro1 Flash Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Flash Replacement: Schritt 2, Bild 1 von 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Flash Replacement: Schritt 3, Bild 1 von 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Flash Replacement: Schritt 4, Bild 1 von 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Flash Replacement, Flash: Schritt 5, Bild 1 von 2 Canon Powershot Pro1 Flash Replacement, Flash: Schritt 5, Bild 2 von 2
    • Remove the 25.4 mm Phillips #0 flash screw. The screw is near the flash.
    • Be careful not to damage the screw.
  6. Canon Powershot Pro1 Flash Replacement: Schritt 6, Bild 1 von 1
    • Locate the small points on both sides of the lens.
    • Pry the lens housing using the black nylon spudger so that it is lifted out of these points.
    • Don't use a screwdriver as a prying tool, this could cause damage.
  7. Canon Powershot Pro1 Flash Replacement: Schritt 7, Bild 1 von 1
    • Use the plastic spudger to remove the upper portion of the flash housing.
  8. Canon Powershot Pro1 Flash Replacement: Schritt 8, Bild 1 von 3 Canon Powershot Pro1 Flash Replacement: Schritt 8, Bild 2 von 3 Canon Powershot Pro1 Flash Replacement: Schritt 8, Bild 3 von 3
    • Use the nylon spudger to dislodge the flash bulb and capacitor from the housing.
    • Don't use a screwdriver as prying tool, this could cause damage.
  9. Canon Powershot Pro1 Flash Replacement: Schritt 9, Bild 1 von 1
    • Cut the flash and capacitor cables with a wire cutter.
Abschluss
Seana Meegan
662 Reputation
5 Anleitungen geschrieben
University of Alabama, Team S1-G1, Bedsole Fall 2019 Mitglied von University of Alabama, Team S1-G1, Bedsole Fall 2019
UA-BEDSOLE-F19S1G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 763
