Zum Hauptinhalt wechseln
Canon Powershot Pro1 Lens Replacement
Was du brauchst
  1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: Schritt 1, Bild 1 von 2 Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: Schritt 1, Bild 2 von 2
    • Have the lens of the camera facing upwards.
    • Find the red plastic ring.
    • Look for two small opening above the red plastic ring.
    • Reference to the left of the picture and you will see the orange square.
  2. Canon Powershot Pro1 Lens Replacement: Schritt 2, Bild 1 von 3 Canon Powershot Pro1 Lens Replacement: Schritt 2, Bild 2 von 3 Canon Powershot Pro1 Lens Replacement: Schritt 2, Bild 3 von 3
    • Remove the plastic ring that has a red strip.
    • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
  3. Canon Powershot Pro1 Lens Replacement: Schritt 3, Bild 1 von 3 Canon Powershot Pro1 Lens Replacement: Schritt 3, Bild 2 von 3 Canon Powershot Pro1 Lens Replacement: Schritt 3, Bild 3 von 3
    • Place the camera on its back with the lens facing upwards as shown in the image
    • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
    • Remove the screw by turning the Philip driver counterclockwise.
    • By removing the screw, you will be able to remove the cover lens.
  4. Canon Powershot Pro1 Lens Replacement: Schritt 4, Bild 1 von 1
    • Use the nylon spudger to remove the ring holding the lens in place.
    • Pull gently until the lens ring snaps off.
  5. Canon Powershot Pro1 Lens Replacement: Schritt 5, Bild 1 von 1
    • Refer to the left-hand pictere to see what the len's ring looks like.
  6. Canon Powershot Pro1 Lens Replacement: Schritt 6, Bild 1 von 3 Canon Powershot Pro1 Lens Replacement: Schritt 6, Bild 2 von 3 Canon Powershot Pro1 Lens Replacement: Schritt 6, Bild 3 von 3
    • Take out the lens once the plastic ring is removed
    • Hold the outer layer of the lens to not create smudges on it.
    • Replace the lens and follow the instruction in reversed order to reassemble the camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Seana Meegan
662 Reputation
5 Anleitungen geschrieben
University of Alabama, Team S1-G1, Bedsole Fall 2019 Mitglied von University of Alabama, Team S1-G1, Bedsole Fall 2019
UA-BEDSOLE-F19S1G1
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Hi, can you do a guide on how to repair the diaphragm?
OTVaL - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 69
Insgesamt: 2,392
