Zum Hauptinhalt wechseln
Canon Powershot Pro1 Motherboard Replacement
Was du brauchst
  1. Canon Powershot Pro1 Motherboard  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Motherboard  Replacement: Schritt 2, Bild 1 von 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Motherboard  Replacement: Schritt 3, Bild 1 von 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Motherboard  Replacement: Schritt 4, Bild 1 von 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: Schritt 5, Bild 1 von 3 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: Schritt 5, Bild 2 von 3 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Open the screen to access the underside of the camera.
  6. Canon Powershot Pro1 Motherboard  Replacement: Schritt 6, Bild 1 von 3 Canon Powershot Pro1 Motherboard  Replacement: Schritt 6, Bild 2 von 3 Canon Powershot Pro1 Motherboard  Replacement: Schritt 6, Bild 3 von 3
    • Using the Phillips #000 screwdriver:
    • Remove two 1.00 mm screws under the viewfinder.
    • Remove one screw in the battery compartment.
    • Remove five screws on the bottom of the camera.
    • Remove one screw on the left side of the camera (opposite the battery compartment).
  7. Canon Powershot Pro1 Motherboard  Replacement: Schritt 7, Bild 1 von 3 Canon Powershot Pro1 Motherboard  Replacement: Schritt 7, Bild 2 von 3 Canon Powershot Pro1 Motherboard  Replacement: Schritt 7, Bild 3 von 3
    • Completely detach the cover from the motherboard.
    • Lift the inside cover to reveal the motherboard.
    • Detach the bottom right ribbon cable from the motherboard.
  8. Canon Powershot Pro1 Motherboard  Replacement: Schritt 8, Bild 1 von 2 Canon Powershot Pro1 Motherboard  Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Lift up the gold insulation cover to reveal the motherboard.
    • Use tweezers and an iFixit opening tool, detach any wire connectors and ribbon cables from the motherboard.
  9. Canon Powershot Pro1 Motherboard  Replacement: Schritt 9, Bild 1 von 3 Canon Powershot Pro1 Motherboard  Replacement: Schritt 9, Bild 2 von 3 Canon Powershot Pro1 Motherboard  Replacement: Schritt 9, Bild 3 von 3
    • Once detached from all connectors and ribbon cables, remove the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Seana Meegan
662 Reputation
5 Anleitungen geschrieben
University of Alabama, Team S1-G1, Bedsole Fall 2019 Mitglied von University of Alabama, Team S1-G1, Bedsole Fall 2019
UA-BEDSOLE-F19S1G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 834
