Zum Hauptinhalt wechseln
Canon Powershot S110 Option Dial Replacement
Was du brauchst
  1. Canon Powershot S110 Option Dial Replacement, Option Dial: Schritt 1, Bild 1 von 2 Canon Powershot S110 Option Dial Replacement, Option Dial: Schritt 1, Bild 2 von 2
    • Remove the battery by sliding open the battery cover on the bottom of the camera.
    • The battery must be removed to avoid shorting out any part of the camera.
  2. Canon Powershot S110 Option Dial Replacement: Schritt 2, Bild 1 von 3 Canon Powershot S110 Option Dial Replacement: Schritt 2, Bild 2 von 3 Canon Powershot S110 Option Dial Replacement: Schritt 2, Bild 3 von 3
    • Remove the six screws by using a small Phillips head screwdriver.
    • Remove the two screws on the side of the camera on either side of the HDMI input panel.
    • Remove the two screws on the opposite side of the camera.
    • Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
  3. Canon Powershot S110 Option Dial Replacement: Schritt 3, Bild 1 von 1
    • Using an opening tool, carefully remove the outermost cover of the camera from its holders around the edges.
    • Once all of the clips around the plastic cover are released, the cover will lift off.
  4. Canon Powershot S110 Option Dial Replacement: Schritt 4, Bild 1 von 2 Canon Powershot S110 Option Dial Replacement: Schritt 4, Bild 2 von 2
    • Remove the two screws holding the top plastic bracket in place by using a Phillips head screwdriver.
    • Remove the screw holding down the lens cover.
    • Remove the screw located near the option dial next to the USB connections.
  5. Canon Powershot S110 Option Dial Replacement: Schritt 5, Bild 1 von 1
    • Carefully lift the top panel of the camera by using a prying tool.
  6. Canon Powershot S110 Option Dial Replacement: Schritt 6, Bild 1 von 1
    • Remove the screw at the center of the option dial by using a Phillips head screwdriver.
  7. Canon Powershot S110 Option Dial Replacement: Schritt 7, Bild 1 von 2 Canon Powershot S110 Option Dial Replacement: Schritt 7, Bild 2 von 2
    • Remove the underlying component that was attached to the now-removed screw by using a prying tool.
    • Remove the dial on the opposite side of the part using a prying tool.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
akac92
298 Reputation
2 Anleitungen geschrieben
UW Tacoma, Team 1-2, Liner SU 2015 Mitglied von UW Tacoma, Team 1-2, Liner SU 2015
UWT-LINER-SU15S1G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 1,111
