Einleitung
The motherboard is what contains and connects the principal components of the camera and controls all of its functions. If there is an electronic issue with your camera, for example if auto-focus is no longer functional, there is a high chance that there is an issue with the motherboard. This guide is moderately difficult and will take some time and patience but requires very few tools. It will walk you through all of the steps needed to disassemble the Canon Powershot S200 camera in order to take out the motherboard.
Was du brauchst
Position the camera so that the bottom is facing up.
Remove the two 2.3mm screws beneath the name plate.
Remove the two 2.8 mm screws surrounding the threaded tripod mount.
Remove the two outer 3.2mm screws from the left side of the camera
Remove the two inner 3.7mm screws from the left side of the camera.
Pull the back face panel away from the front end of the body. This may take some wiggling and force.
