Einleitung
The flash bulb is essential for to take dimly lit photographs. If the flash goes out, your camera will have severely limited functionality.
Was du brauchst
Remove the 3.2 mm screw from the right side of the camera.
Remove the 2.2 mm screw from the right side of the camera.
Lift the side panel off.
Remove the 1.8 mm screw from underneath the side panel.
Remove the two 2.2 mm screws from the left side of the camera.
Lift the plate from the camera.
Peel the navigation buttons from the button panel and set them aside.
To free the LCD display, remove the 2.9 mm screw in the top left corner.
Rotate the screen clockwise until it lifts away from the camera.
To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
After disconnecting both cables, pull the screen away from the camera to remove it.
Once the image sensor is removed, turn the camera over and find the screw in the bottom right corner.
Remove this .01 inch screw to free the ribbon cables.
Flip the camera over again so that the rear is showing and remove the two .065 inch screws holding the flash unit in place. They should be on the left side.
