Zum Hauptinhalt wechseln
Canon Powershot SD550 Image Sensor Replacement
Was du brauchst
  1. Canon Powershot SD550 Image Sensor Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Image Sensor Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Image Sensor Replacement: Schritt 3, Bild 1 von 3 Canon Powershot SD550 Image Sensor Replacement: Schritt 3, Bild 2 von 3 Canon Powershot SD550 Image Sensor Replacement: Schritt 3, Bild 3 von 3
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Image Sensor Replacement: Schritt 4, Bild 1 von 3 Canon Powershot SD550 Image Sensor Replacement: Schritt 4, Bild 2 von 3 Canon Powershot SD550 Image Sensor Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Image Sensor Replacement: Schritt 5, Bild 1 von 3 Canon Powershot SD550 Image Sensor Replacement: Schritt 5, Bild 2 von 3 Canon Powershot SD550 Image Sensor Replacement: Schritt 5, Bild 3 von 3
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Image Sensor Replacement: Schritt 6, Bild 1 von 3 Canon Powershot SD550 Image Sensor Replacement: Schritt 6, Bild 2 von 3 Canon Powershot SD550 Image Sensor Replacement: Schritt 6, Bild 3 von 3
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
  7. Canon Powershot SD550 Image Sensor Replacement, LCD Screen: Schritt 7, Bild 1 von 3 Canon Powershot SD550 Image Sensor Replacement, LCD Screen: Schritt 7, Bild 2 von 3 Canon Powershot SD550 Image Sensor Replacement, LCD Screen: Schritt 7, Bild 3 von 3
    • Peel the navigation buttons from the button panel and set them aside.
    • To free the LCD display, remove the 2.9 mm screw in the top left corner.
    • Rotate the screen clockwise until it lifts away from the camera.
    • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
  8. Canon Powershot SD550 Image Sensor Replacement: Schritt 8, Bild 1 von 2 Canon Powershot SD550 Image Sensor Replacement: Schritt 8, Bild 2 von 2
    • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
    • After disconnecting both cables, pull the screen away from the camera to remove it.
  9. Canon Powershot SD550 Image Sensor Replacement, Image Sensor: Schritt 9, Bild 1 von 2 Canon Powershot SD550 Image Sensor Replacement, Image Sensor: Schritt 9, Bild 2 von 2
    • Now the photo sensor is exposed. In order to remove the ribbon cable from its port, first flip up the blue locking mechanism.
    • After the cable is unlocked, it easily pulls free.
  10. Canon Powershot SD550 Image Sensor Replacement: Schritt 10, Bild 1 von 2 Canon Powershot SD550 Image Sensor Replacement: Schritt 10, Bild 2 von 2
    • In order to remove the photo sensor, you will have to cut through glue and remove screws.
    • Use a knife to carefully slice through the glue at the tree points indicated. Try not to cut through anything but the glue to avoid damage.
    • WARNING: Knives are sharp. Treat them with respect.
    • Now remove the three .15 inch screws holding the photo sensor to the camera frame.
  11. Canon Powershot SD550 Image Sensor Replacement: Schritt 11, Bild 1 von 2 Canon Powershot SD550 Image Sensor Replacement: Schritt 11, Bild 2 von 2
    • Now you can carefully lift up the image sensor and remove it from the camera.
    • Be careful not to lose the three small springs or the rubber grommet that lie beneath the sensor.
  12. Canon Powershot SD550 Image Sensor Replacement: Schritt 12, Bild 1 von 1
    • You have now successfully removed the image sensor.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Matthew Theiss
176 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 18-23, Garner Spring 2011 Mitglied von Cal Poly, Team 18-23, Garner Spring 2011
CPSU-GARNER-S11S18G23
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 2,785
