Einleitung
The shutter button is one of the most commonly used buttons on a camera. Therefore, it is also the most likely to break.
Was du brauchst
Remove the 3.2 mm screw from the right side of the camera.
Remove the 2.2 mm screw from the right side of the camera.
Lift the side panel off.
Remove the 1.8 mm screw from underneath the side panel.
Remove the two 2.2 mm screws from the left side of the camera.
Lift the plate from the camera.
Next, unscrew the .115 inch screw fastening the shutter button to the camera.
Now lift the button away from the camera, exposing the button board.
You have successfully removed the shutter button.
