Einleitung
The outer casing covers the internal mechanisms of the camera.
Was du brauchst
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
