Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen. Remove the 2 screws (4.08 mm) on the other side.  One is located under the rubber USB flap. Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
    • Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
    • Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Slowly pull the back cover of the camera.
  2. Das Essential Toolkit
    Die nützlichsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  3. Remove the screw (2.59 mm) from the bottom of the camera. Remove the screw (4.08 mm) from the menu button side of the camera. Note: the 2 screws on the other side of the camera were already removed when taking off the back cover.
    • Remove the screw (2.59 mm) from the bottom of the camera.
    • Remove the screw (4.08 mm) from the menu button side of the camera.
    • Note: the 2 screws on the other side of the camera were already removed when taking off the back cover.
Abschluss
Robert Manno
432 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-3, Forte Winter 2011 Mitglied von Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 2,694
