Zum Hauptinhalt wechseln
Canon Powershot SD880 Front Cover Replacement
Was du brauchst
  1. Canon Powershot SD880 Front Cover Replacement, Back Cover: Schritt 1, Bild 1 von 3 Canon Powershot SD880 Front Cover Replacement, Back Cover: Schritt 1, Bild 2 von 3 Canon Powershot SD880 Front Cover Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Front Cover Replacement, Front Cover: Schritt 2, Bild 1 von 3 Canon Powershot SD880 Front Cover Replacement, Front Cover: Schritt 2, Bild 2 von 3 Canon Powershot SD880 Front Cover Replacement, Front Cover: Schritt 2, Bild 3 von 3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
Abschluss
Robert Manno
432 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-3, Forte Winter 2011 Mitglied von Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 2,799
