Was du brauchst
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
