Zum Hauptinhalt wechseln
Canon Powershot SD880 LCD Display Replacement
Was du brauchst
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: Schritt 1, Bild 1 von 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: Schritt 1, Bild 2 von 3 Canon Powershot SD880 LCD Display Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: Schritt 2, Bild 1 von 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: Schritt 2, Bild 2 von 3 Canon Powershot SD880 LCD Display Replacement, LCD Display: Schritt 2, Bild 3 von 3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
Abschluss
Ben Tupas
317 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 13-3, Forte Winter 2011 Mitglied von Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 18
Insgesamt: 2,320
