Zum Hauptinhalt wechseln
Canon Powershot SX10 IS LCD Screen Replacement
Was du brauchst
  1. Canon Powershot SX10 IS LCD Screen Replacement, Lithium Ion Battery: Schritt 1, Bild 1 von 1
    • Open the door. Release the catch by sliding it towards the side of the camera.
    • Then slide the door towards the front of the camera.
  2. Canon Powershot SX10 IS LCD Screen Replacement: Schritt 2, Bild 1 von 3 Canon Powershot SX10 IS LCD Screen Replacement: Schritt 2, Bild 2 von 3 Canon Powershot SX10 IS LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Remove AA batteries.
    • Using a fingernail or iFixit opening tools to pry up the battery cradle.
    • Remove CR1220 battery from the cradle.
  3. Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: Schritt 3, Bild 1 von 2 Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: Schritt 3, Bild 2 von 2
    • Remove all four screws on the corners of the screen cover.
    • Gently pry open the cover with a fingernail or iFixit opening tool.
  4. Canon Powershot SX10 IS LCD Screen Replacement: Schritt 4, Bild 1 von 3 Canon Powershot SX10 IS LCD Screen Replacement: Schritt 4, Bild 2 von 3 Canon Powershot SX10 IS LCD Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove two screws holding on the cover plate on the pivot.
    • Remove the cover plate using an iFixit opening tool.
    • You may need to loosen the bottom first, then pry on the top of the cover plate.
    • Remove the two screws on top of the swivel arm. These two screws will be separated by the pivot point.
  5. Canon Powershot SX10 IS LCD Screen Replacement: Schritt 5, Bild 1 von 3 Canon Powershot SX10 IS LCD Screen Replacement: Schritt 5, Bild 2 von 3 Canon Powershot SX10 IS LCD Screen Replacement: Schritt 5, Bild 3 von 3
    • Remove grounding wire, then continue to remove the screws holding the screen and front cover plate on.
    • The screen and plate will drop after removing the last screw.
  6. Canon Powershot SX10 IS LCD Screen Replacement: Schritt 6, Bild 1 von 2 Canon Powershot SX10 IS LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Unlatch the ribbon strip and power wires from the circuit board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 1,230
