Was du brauchst
Open the protective door on the bottom of the camera, and remove the SD card and battery from the camera
Remove the plastic backing and the metal front plate from the spring controlled hinge
To replace, hold the plastic backing to the metal hinge and screw the plate onto the front of it
Fast fertig!
That's It! Good Job!
Abschluss
Ein Kommentar
What if the existing hinge is broken.....I need to replace the entire door and spring loaded hinge. Ya got instructions for that?
