Zum Hauptinhalt wechseln
Canon Powershot SX30 IS Battery/SD Card Door Replacement
Was du brauchst
  1. Canon Powershot SX30 IS Battery/SD Card Door Replacement, Battery/SD Card Door: Schritt 1, Bild 1 von 1
    • Open the protective door on the bottom of the camera, and remove the SD card and battery from the camera
  2. Canon Powershot SX30 IS Battery/SD Card Door Replacement: Schritt 2, Bild 1 von 2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the two 2mm screws from the inside of the case
  3. Canon Powershot SX30 IS Battery/SD Card Door Replacement: Schritt 3, Bild 1 von 2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: Schritt 3, Bild 2 von 2
    • Remove the plastic backing and the metal front plate from the spring controlled hinge
    • To replace, hold the plastic backing to the metal hinge and screw the plate onto the front of it
Abschluss
That's It! Good Job!
Ellis DeVoe
580 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 5-12, Maness Spring 2015 Mitglied von Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 Mitglieder
Ein Kommentar
What if the existing hinge is broken.....I need to replace the entire door and spring loaded hinge. Ya got instructions for that?
jusanotherhuman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 645
