Einleitung
User will need PH00 screwdriver and plastic pry tools for this replacement guide.
Was du brauchst
Push the small orange tab forward to release the battery (Battery is ready for removal).
Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
