Einleitung
User needs PH00 screwdriver, spudger, and plastic pry tool.
Was du brauchst
Push the small orange tab forward to release the battery (Battery is ready for removal).
Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
