Einleitung
The Canon SX40HS is a high-powered, user-friendly digital camera. The SX40 HS is a great entry-level camera that provides simplicity and quality at a low cost. Due to wear and tear, it is important to know how to change the flash cover. This guide is geared towards everyday photographers and professionals.
Was du brauchst
Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
Repeat to remove the 4 mm black screw located on the right side.
After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
To reassemble your device, follow Steps 1-4 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
