Einleitung
This guide shows how to replace the cooling fan of the Canon Selphy CP12000. This replacement may be necessary if the cooling fan is faulty or the device is overheating excessively.
Was du brauchst
Gently pry open the top of the case from either the front or back.
Be careful in lifting the top assembly as it is attached to the motherboard at this point.
Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
The top assembly, containing both the LCD and buttons, will now be completely free
Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
Open the side door and depress the ink cassette release.
Slide out and remove the ink cassette.
Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
