Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The Canon Selphy CP910 is used to print pictures from a camera and WiFi connection. If there are any issues with the buttons on the printer, it may be necessary to remove them. For information regarding troubleshooting issues with the Canon Selphy CP910, go to Canon Selphy CP910 Troubleshooting.
Contact the manufacturer for inquiries about receiving parts of the Canon Selphy CP910.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn the printer over. Use the PH1 screw bit to  remove the three 8 mm screws in the middle of the back plate.
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Loosen up the four 10 mm corner screws. A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws. A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Turn the device around and remove the "open" lid. This lid needs to be removed in order to take the printer apart. Gently bend the lid and remove it from its hinges.
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Das Essential Electronics Toolkit
    Die wichtigsten Werkzeuge in unserem kompaktesten Kit.
    Jetzt kaufen
    Jetzt kaufen
  5. Turn the device back over and lift the top panel up. Disconnect the ribbon cables leading to the LCD screen. Pull the top panel off.
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  6. Turn the top panel over so the inside faces toward you. Turn the top panel over so the inside faces toward you.
    • Turn the top panel over so the inside faces toward you.
  7. Use the PH0 screw bit to remove the  five 10 mm screws located above the circuit board. Use the PH0 screw bit to remove the  five 10 mm screws located above the circuit board. Use the PH0 screw bit to remove the  five 10 mm screws located above the circuit board.
    • Use the PH0 screw bit to remove the five 10 mm screws located above the circuit board.
  8. Carefully remove the frame attached to the screen. Carefully remove the frame attached to the screen.
    • Carefully remove the frame attached to the screen.
  9. Take out the circuit board. Once you take out the circuit board, you should be left with just the case. Once you take out the circuit board, you should be left with just the case.
    • Take out the circuit board.
    • Once you take out the circuit board, you should be left with just the case.
  10. There is a clear plastic “L” shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it. Remove the button framework and replace it with new one.
    • There is a clear plastic “L” shaped piece that acts as the power light for the printer. The piece is not attached to the printer so take care not to lose it.
    • Remove the button framework and replace it with new one.
Abschluss
Christie Peralta
664 Reputation
5 Anleitungen geschrieben
UW Tacoma, Team 1-6, Rose Winter 2016 Mitglied von UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 523
