Zum Hauptinhalt wechseln
Canon Vixia HF R500 Battery Charger Replacement
Was du brauchst
  1. Canon Vixia HF R500 Battery Charger Replacement, Grip Belt: Schritt 1, Bild 1 von 3 Canon Vixia HF R500 Battery Charger Replacement, Grip Belt: Schritt 1, Bild 2 von 3 Canon Vixia HF R500 Battery Charger Replacement, Grip Belt: Schritt 1, Bild 3 von 3
    • On the right side of the camcorder remove the grip belt.
  2. Canon Vixia HF R500 Battery Charger Replacement, Battery: Schritt 2, Bild 1 von 1
    • Hold on to the battery.
  3. Canon Vixia HF R500 Battery Charger Replacement: Schritt 3, Bild 1 von 1
    • On the bottom of the battery hold the battery release switch.
  4. Canon Vixia HF R500 Battery Charger Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery slowly away from the camcorder.
    • Removing the battery quick or in a different angle may cause sparks and damage to device.
  5. Canon Vixia HF R500 Battery Charger Replacement, Canon Vixia HF R500 Disassembly: Schritt 5, Bild 1 von 2 Canon Vixia HF R500 Battery Charger Replacement, Canon Vixia HF R500 Disassembly: Schritt 5, Bild 2 von 2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  6. Canon Vixia HF R500 Battery Charger Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  7. Canon Vixia HF R500 Battery Charger Replacement: Schritt 7, Bild 1 von 1
    • Remove the side piece plate.
  8. Canon Vixia HF R500 Battery Charger Replacement: Schritt 8, Bild 1 von 1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  9. Canon Vixia HF R500 Battery Charger Replacement: Schritt 9, Bild 1 von 1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  10. Canon Vixia HF R500 Battery Charger Replacement: Schritt 10, Bild 1 von 1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  11. Canon Vixia HF R500 Battery Charger Replacement: Schritt 11, Bild 1 von 3 Canon Vixia HF R500 Battery Charger Replacement: Schritt 11, Bild 2 von 3 Canon Vixia HF R500 Battery Charger Replacement: Schritt 11, Bild 3 von 3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  12. Canon Vixia HF R500 Battery Charger Replacement: Schritt 12, Bild 1 von 1
    • Remove the top piece.
  13. Canon Vixia HF R500 Battery Charger Replacement, Battery Charger: Schritt 13, Bild 1 von 1
    • Ensure the ribbon cord is connected
    • Check the condition of the ribbon cord and replace damaged cord.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 965
