Einleitung
The charging port of the Canon Vixia HF R500 is connected by a fragile ribbon cord. This cord can become damaged or disconnected preventing the battery from charging. This guide will show you how to check the connection.
Was du brauchst
Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
A hidden 4mm Philips #000 screw is shown under the black plug shown.
Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
Ensure the ribbon cord is connected
Check the condition of the ribbon cord and replace damaged cord.
