Zum Hauptinhalt wechseln
Canon Vixia HF R500 Disassembly
Was du brauchst
  1. Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: Schritt 1, Bild 1 von 2 Canon Vixia HF R500 Disassembly, Canon Vixia HF R500 Disassembly: Schritt 1, Bild 2 von 2
    • Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
  2. Canon Vixia HF R500 Disassembly: Schritt 2, Bild 1 von 1
    • Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
    • A hidden 4mm Philips #000 screw is shown under the black plug shown.
  3. Canon Vixia HF R500 Disassembly: Schritt 3, Bild 1 von 1
    • Remove the side piece plate.
  4. Canon Vixia HF R500 Disassembly: Schritt 4, Bild 1 von 1
    • Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
  5. Canon Vixia HF R500 Disassembly: Schritt 5, Bild 1 von 1
    • Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
    • Do not use strong magnetic parts on the inside, as they may damage the device.
  6. Canon Vixia HF R500 Disassembly: Schritt 6, Bild 1 von 1
    • Using the spudger, pull the tab shown to start removing the ribbon cable.
  7. Canon Vixia HF R500 Disassembly: Schritt 7, Bild 1 von 3 Canon Vixia HF R500 Disassembly: Schritt 7, Bild 2 von 3 Canon Vixia HF R500 Disassembly: Schritt 7, Bild 3 von 3
    • Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
  8. Canon Vixia HF R500 Disassembly: Schritt 8, Bild 1 von 1
    • Remove the top piece.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 696
