Einleitung
If the lens cover on your camera will not open or close it could be caused by debris blocking the mechanism or a broken mechanism component. This guide will show you how to remove the lens cover from your camera so you can clean or repair it.
Was du brauchst
Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
A hidden 4mm Philips #000 screw is shown under the black plug shown.
Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
Remove the single 5mm Phillips #000 screw located on the top of the camera near the lens cover.
Unplug the cord connecting the camera to the lens cover. Grip the white plug near the port and pull it out.
The lens cover is detached from the camera and can now be removed.
Repair or replace damaged components in the lens cover.
Ensure lens cover mechanism is free of debris.
