Einleitung
This guide will show you how to access the components of the manual zoom to repair or replace broken elements.
Was du brauchst
Remove the two 8mm Philips #000 screws on the side where the grip belt was located on.
Remove the two 4mm Philips #000 head screws from the bottom of the camcorder.
A hidden 4mm Philips #000 screw is shown under the black plug shown.
Near the LCD screen, remove the three 7mm Philips #000 screws in the picture shown.
Carefully place the camcorder where the inside of the device is facing upwards and remove the 3mm Philips #000 screw shown.
Using the Spudger, carefully remove the two ribbon cables that are connected to the top of the device.
Remove the three 6mm Philips #000 screws holding the black record piece.
Holding the full top piece remove the six 5mm Philips #000 screws holding the metal frame to the top piece.
Examine the grey zoom input tab located on copper plate.
Examine the black plastic zoom slider, on the top cover of the camera
Repair or replace damaged components and clear all debris from mechanisms.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
