Zum Hauptinhalt wechseln
Canon Vixia HF R600 Casing Replacement
Was du brauchst
  1. Canon Vixia HF R600 Casing Replacement, Handstrap: Schritt 1, Bild 1 von 2 Canon Vixia HF R600 Casing Replacement, Handstrap: Schritt 1, Bild 2 von 2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Casing Replacement: Schritt 2, Bild 1 von 2 Canon Vixia HF R600 Casing Replacement: Schritt 2, Bild 2 von 2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Casing Replacement, Battery: Schritt 3, Bild 1 von 2 Canon Vixia HF R600 Casing Replacement, Battery: Schritt 3, Bild 2 von 2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Casing Replacement, Casing: Schritt 4, Bild 1 von 2 Canon Vixia HF R600 Casing Replacement, Casing: Schritt 4, Bild 2 von 2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Casing Replacement: Schritt 5, Bild 1 von 2 Canon Vixia HF R600 Casing Replacement: Schritt 5, Bild 2 von 2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Casing Replacement: Schritt 6, Bild 1 von 2 Canon Vixia HF R600 Casing Replacement: Schritt 6, Bild 2 von 2
    • Gently pull the plastic casing away from the camera.
Abschluss
Logan Coats
522 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 14-4, Lacy Spring 2016 Mitglied von USF Tampa, Team 14-4, Lacy Spring 2016
USFT-LACY-S16S14G4
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 414
