Zum Hauptinhalt wechseln
Canon Vixia HF R600 Microphone Replacement
Was du brauchst
  1. Canon Vixia HF R600 Microphone Replacement, Handstrap: Schritt 1, Bild 1 von 2 Canon Vixia HF R600 Microphone Replacement, Handstrap: Schritt 1, Bild 2 von 2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Microphone Replacement: Schritt 2, Bild 1 von 2 Canon Vixia HF R600 Microphone Replacement: Schritt 2, Bild 2 von 2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Microphone Replacement, Battery: Schritt 3, Bild 1 von 2 Canon Vixia HF R600 Microphone Replacement, Battery: Schritt 3, Bild 2 von 2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Microphone Replacement, Casing: Schritt 4, Bild 1 von 2 Canon Vixia HF R600 Microphone Replacement, Casing: Schritt 4, Bild 2 von 2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Microphone Replacement: Schritt 5, Bild 1 von 2 Canon Vixia HF R600 Microphone Replacement: Schritt 5, Bild 2 von 2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Microphone Replacement: Schritt 6, Bild 1 von 2 Canon Vixia HF R600 Microphone Replacement: Schritt 6, Bild 2 von 2
    • Gently pull the plastic casing away from the camera.
  7. Canon Vixia HF R600 Microphone Replacement, Microphone: Schritt 7, Bild 1 von 3 Canon Vixia HF R600 Microphone Replacement, Microphone: Schritt 7, Bild 2 von 3 Canon Vixia HF R600 Microphone Replacement, Microphone: Schritt 7, Bild 3 von 3
    • Remove one 5mm Phillips PH#00 screw from the top of the camera.
    • Pull away the plastic shutter casing; this contains the microphone.
    • Using the plastic opening tool or something similar, carefully disconnect the white 4 pin connector to remove the shutter casing.
  8. Canon Vixia HF R600 Microphone Replacement: Schritt 8, Bild 1 von 2 Canon Vixia HF R600 Microphone Replacement: Schritt 8, Bild 2 von 2
    • Remove the one 4mm Phillips JIS#00 screw from the top of the shutter housing.
    • Pull the shutter away to reveal the metal plate covering the speakers.
  9. Canon Vixia HF R600 Microphone Replacement: Schritt 9, Bild 1 von 3 Canon Vixia HF R600 Microphone Replacement: Schritt 9, Bild 2 von 3 Canon Vixia HF R600 Microphone Replacement: Schritt 9, Bild 3 von 3
    • Remove the one 4mm Phillips JIS#00 from the plastic shutter housing.
    • Pull the metal bracket out of the housing.
    • Carefully remove the speakers from the housing as they contain very thin wires.
Abschluss
Brian Luna
483 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 14-4, Lacy Spring 2016 Mitglied von USF Tampa, Team 14-4, Lacy Spring 2016
USFT-LACY-S16S14G4
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 290
